Hello everyone, I hope you can help me. My parents own a 1993 Chrysler Fifth Avenue with the 3.3L V6 and A604 4 speed automatic. For the last few years, the transmission has started to act up in cold weather. When you start the car in the morning, the transmission won't engage into any gear until the car is warmed up for about 5-10 minutes. When you start driving, the transmission shifts sluggishly until the car is fully warmed up. Other than that, the transmission works fine.
The transmission ultimately needs a rebuild (new seals), but my parents are thinking about getting a transmission service done to see if that would help. The last time the transmission had its fluid and filter changed was back in 1999.
1. To my knowledge, the correct transmission fluid to use is ATF+4. Dexron should NEVER be used in a A604 transmission, is that correct?
2. Will a synthetic ATF work better than ATF+4? One person I talked to owned a 1994 Lebaron with similar transmission problems - he used Amzoil synthetic ATF, and the delayed engagement problems went away.
3. Does anyone makes a good transmission additive that will condition and soften the seals in the transmission? I have tried Lucas Transmission Fix, but it didn't seem to help at all.
4. What is the best (and safest) way to remove the old transmission fluid? Is a flush recommended? I know many transmission shops have a machine which exchanges the transmission fluid and flushes the transmission.
