And coffee grounds.Grease, baby. Grease.
Yeah never, candy wrappers, etcAnd coffee grounds.
I'm really amazed so many people don't have risers. Makes like zero sense. Did save the builder money though!My septic is legitimately 3 feet down and needs to be dug out every time - he usually brings a young lad with a shovel with him. Last time he was out we discussed putting in risers next time he comes out and that should be soon, thank you for reminding me!
I am told nitrogen from septic water will flow with ground water to aquifer and eventually to bay or ocean.I pay a yearly septic fee to the State for some kind of Chesapeake Bay restoration charge. I think $100.00 per year.
I am many miles from the bay. My septic has zero effect on the bay.
Consult locally, most pumpers will chat a few minutes on good and bad in your area, plus the county too.I have been looking at some Outback property of homes that were built a while ago and these homes are using septic tanks, I am un-educated about what to look for in an older house.?
Should I be looking for that so-called riser? If I understand it correctly that makes pumping out a lot easier. Is this true?
How do you know if your septic tank is maxed out and full and ready for $1,000 pump out? Or is that something that is disclosed on the sale of the house.?
Lastly how do you know how big it is? Meaning if you have a girlfriend that likes to run the water constantly! How soon would that tank fill up.? I thought that most of them they're all done in a PVC now or some type of plastic. Thanks in advance
I used to work in Seal Beach so it's OKOh thanks for that it all sounds so complicated. And it seems like another bill down the road! I'm trying to uncomplicate my life as I am now retired. But I cannot Escape it, it seems everywhere things are becoming more costly and more complicated to fix. I'm not from the country and have no clue about well water or septic tanks when I hear that I think of Toothless folks running around chasing chickens! I know that is probably 100% wrong. But you're right I can't see being that complicated especially if it's been upgraded and assessed. Probably a good home inspector with check all that prior.
In my NY house I finally called the local construction company that pumps septics. He showed up with the truck and a shovel. Dug for awhile then left and came back with a small excavator. He owns the construction company. I think he charged my $20 to dig out the septic tank cover.I'm really amazed so many people don't have risers. Makes like zero sense. Did save the builder money though!
$20 wow!! Nothing for 20 anymoreIn my NY house I finally called the local construction company that pumps septics. He showed up with the truck and a shovel. Dug for awhile then left and came back with a small excavator. He owns the construction company. I think he charged my $20 to dig out the septic tank cover.
He smoothed a few large ruts on my lawn with the blade on the small excavator.
Depending on the total cost of the bill, that does sound like a bargain. I think they charge $50 around me for something that can be dug with a shovel.$20 wow!! Nothing for 20 anymore
I suppose the $100.00 each year is keeping my nitrogen from entering the groundwater.I am told nitrogen from septic water will flow with ground water to aquifer and eventually to bay or ocean.
In a similar manner, dump too much fertilizer on land, plants can only use nitrogen at one time, excess follows ground water to aquifer.
Who knows. I know with my septic with an air pump it's designed to vent the nitrogen into the air. Should be OK since air is 80% nitrogen. So the air around my house might be 80.0001% nitrogen.I suppose the $100.00 each year is keeping my nitrogen from entering the groundwater.
