Seized snow blower motor
Originally Posted By: HerrStig
Maybe you had an ounce or two stuck in there. It's splash lubed and the drain doohickey is threaded into the side of the engine casting. Down low, but still on the side. I tip my OPE to get another 1/2 oz out but even then there's some inside. Did it screech to a stop or maybe some valves hung open and it lost compression and wheezed out? With a load on it it could have stopped fairly abruptly but not from internal jamming.
Surprised you don't have a low oil shutoff doohickey. Though I cut the wire for it on my chondas due to false positives when running my OPE at crazy angles.
Only the pressurized oil system units have a low oil shutoff. Splash lube develops no oil pressure to use on a pressure switch which would open or short the ingnition.
Yet many low cost splash lube engine generators have the low oil shut off switch.
Whimsey
Lots of splash lubed engines have a low oil shutoff, almost all of the Honda GX series come with one or have the option to add one, it's similar to a float switch and can be very aggrevating after spending 20 minutes trying to start a piece of equipment just to realize that it's a little low on oil. As someone who has close to 80 pieces of equipment powered by GX motors I made this error quite a few times over the years.
That's a good point ironman! I've never seen a Honda GX w/out the low oil ignition kill switch.
OP, out of curiosity, what type make/model/style snowblower is this?
