You'll be seeing the Tweel and similar airless tire designs on slow moving construction vehicles and military vehicles long before they will became available for passenger cars.
Supposed to be real stiff turning in but soft absorbing bumps, kind of a best of both worlds scenario. They could put a sidewall on like they do for winter wiper blades to keep stuff out.
When I read the title, I was expecting to see tires made of 'clear rubber', like the Quaker State Synthetic oil bottles (although they are plastic...)...that would have been cool....
Those appear to be solid rubber with holes in them.
The Tweel appears to be a combination of rubber and polyurethane spokes. Apparently a Segway concept ATV featured a prototype Tweel from Michelin.
The Tweel concept isn't much different than the Adidas a3 athletic shoe sole. They use polyurethane members sandwiched between the tread and body, rather than something like foam, gel, or air bladders.
Originally Posted By: Shannow
They'd have sidewalls on them for sure if produced.
I would imagine sidewalls would help when it comes to air resistance. However - I could see how leaving the interior matrix open could help beyond just the cool factor.
It would be easier to inspect the interior for any failure of a spoke. It might help with cooling of the tread. Sealing it might affect the dynamic structure.
If the spoke section is durable enough, I could see where one could have a semi-permanent wheel and an attached tire.
