Good answers; keep 'emcoming!
I just ran accross an SAE paper about how much more aggressive toward floroelastomer seals ("Viton") the newest generation turbine oils such as Mobil Jet Oil 291 are compared to older turbine oils, like Mobil Jet Oil II.quote:
Originally posted by MolaKule:
The answer is E and B in that order.
While esters can cause seal swelling by altering the plasticizer a bit, Dispersants not only can extract the plasticizer but also alter other material properties of the seal.
Dispersants containing high nitrogen content (such as amine-type or succinimide-type dispersants) have been implicated in causing seal damage to fluoroelastomer seals such as Viton. The low molecular weight and high polarity molecules in some dispersants can "diffuse" into the seal material and extract the plasticizer. [The plasticizer is that material which makes the seal pliable.]
Seal and Fluid Test
I. Goal of Experiment:
Determine fluid effect on common fluorocarbon elastomer seal materials using two dissimilar synthetic base oils.
II. Materials Used and Test Protocol:
Pure, non-additized fluids were used in 250 mL quantities to cover seals and placed inside a 2-L beaker; one fluid was a 12 cSt Di-Ester, the other a 12 cSt Polyol Ester. Test duration was 45 days. Fluid temperature was brought up to 150 C for thirty minutes every other day, while air was pumped through hot oil using an Aquarium pump.
Seals were all new Flourocarbon elastomer seals from various seal manufacturers and included rear main engine seals for GM Chevy small block engine, input-pinion drive seals for Chevy 10-bolt differential, and axle seals for Chevy Suburban 4X4. Seals were cleaned with hexane after experiment, allowed to dry, and their weights re-measured on an electronic scale accurate to within 0.01 grams. A new set of seals was used for each fluid experiment.
III. Test Results
1. Di-Ester
A. Durometer - 5.3% (toward softness)
B. Flexibility – increased slightly
C. Peeling, cracking, or any other physical damage – none.
D. Dimensional change – + 7%; increase in lip height and decrease in radial dimension.
E. Wetting and Fluid cling – good.
F. Effects on Steel core – none; no rusting, no scale or discoloration.
G. Fluid Color and opacity change – showed a slight change in color toward a darker amber and a slight increase in cloudiness.
H. Weight Change – no detectable change.
2. Polyol Ester
A. Durometer – 3.7% softer after test.
D. Dimensional change – + 5.7%; increase in lip height and decrease in radial dimension
E. Wetting and Fluid cling – Excellent.
G. Fluid Color Change - ! No darkening and no change in transparency. No color shift.
IV. Discussion Topics:
A. Durometer – Change in hardness or softness of material?
This measures an increase or decrease in the bulk hardness or softness of the material after soaking and temperature cycling.
From the results of this test (by no means totally scientific), we see that di-esters make a seal more soft than do polyol esters.
In our case, we used a spring loaded mechanical pressure guage that was lowered a specific distance to emulate a duromoter machine. The stiffness was measured before the experiment, and then afterwards. The softer the material, the more the pressure guage depressed into the material. The less the guage tip pressed into the material, the stiffer it was.
B. Flexibility – Did material increase or decrease in flexibility?
In our case, we used a spring loaded mechanical pressure guage to displace the lip edges a prescribed amount. We could not detect any changes down to 0.01 gram.
C. Peeling, cracking, or any other physical damage?
Some chemicals will cause the seal to peel, crack, or show some other damage during soaking and after washing. Neither of these fluids showed any physical damage as per above.
D. Dimensional change – A “+” represents seal swell while a “-“ represents seal shrinkage. A certain amount of seal swell allows for a tighter seal and reduces the potential of leakage. If the seal shrinks, you will have leaks. In Group IV majority formulations, one needs some kind of seal swell to balance out the slight shrinkage or “non-swelling” from PAO’s. I personally was NOT surprised at the results since other testing with various ester formulations of all types had not shown any real seal swell issues.
E. Wetting and Fluid cling – Subjective observation. Since the viscosities were almost equal, we timed how long it would take for oil to drip off the seals, and how well the fluid “wetted” the seals. All seals were well wetted but the polyol ester showed the best fluid cling.
F. Effects on Steel core/backing – rusting, scale, separation from elastomer, or discoloration? Since there were no anti-oxidant or
metal deactivator additives in the base oils, one might see slight oxidation of the core/backing. None was observed.
H. Fluid Color Change - ! Darkening and or change in color?
I considered this item to be a very important test item because a change in color or transparency meant that seal material might have migrated into the fluid, and or the fluid may have “diffused” into the seal material, displacing fluoroelastomer molecules. As seen in this test, the Polyol Ester was the most stable fluid. The di-ester showed very slight darkening, a slight increase in cloudiness, and a slight change in color toward a darker amber.
I. Weight Change – Measure weight to see if mass was gained or depleted. This is related to items “A” and “H.” Any mass gain of the seal might indicate fluid diffusion into the seal material.
V. Summary
While not an “official” scientific or ASTM test, the base oils tested showed remarkable stability. The seals showed only slight swelling.
The only thing we did not duplicate was localized heating due to shaft rotation as in actual axle or engine operation.
