How hot is hot, and how cold is cold?Remember when tranny dipsticks were marked with a cold and hot level??? Too easy.
Ya got me... But I am lousy at following directions. I am getting a little better, though...How hot is hot, and how cold is cold?
The average consumer has ZERO NEED to check the fluid in a sealed system- and does not change the fluid themselves. The condition of the fluid can be changed under the "severe schedule" in the owners manual. The average vehicle owner (if vehicle is purchased new) will pay to have the fluid changed a maximum of two times during ownership, most once. The sealed transmission in my wife's Hyundai was also a PITA and I had an independent change it using Maxlife. Lamenting a lack of a dipstick is a DIY BITOG "thing".I bought some new fluid for the auto transmission in my 2014 Passat. I googled the method for replacement. Pain in the tush. My theory is the reason for deleting the dipstick is twofold: 1. saves the cost of manufacturing and installing the dipstick & tube. 2. Easier to transport with no escape route for the ATF. I don't think there is any benefit in this for the consumer.
When I changed the fluid/filters in the Versa CVT a few weeks ago it had 29993 miles. The fluid in it wasn't black but wasn't far from it. New fluid color was a light green or light blue I don't recall which.The car (2014 Passat Wolfsburg) has only 51K miles on it and the fluid was black. I guess this will became an annual ritual for me.
Yup done this nine times on the Hyundai no problems. Drained it hot a couple times as well, volume of fluid wasn't measurably different, I always get exactly a hair over 3.5 qts or halfway between 3.5 qts and 3.5L on my measuring jug, hot or cold.If it has factory fill, Drain it cold-measure amount-put same amount back in. No need to measure temp which you have to do if you drain it hot.
I have one from Ace Hardware from the paint department. Wasn't much.Dollar stores usually sell graduated plastic pitchers that can be used (I do) and a piece of masking tape can be attached to temp mark the level...
Not looking forward to the day when i service the 13 sonata. No dip stick, and a "sealed" unit with only a bolt you remove to drain, and a "inspection" port you use to fill the fluid up to... Hyundai wants $350 from what i remember for this service..
The Elantra on the other hand was a walk in the park. It has a dip stick, that is clearly marked and a drain bolt on the pan, with a removable pan if you wanted to clean the magnets and change the filter.. Very nice design.
