SeaFoam through the fuel hole ?
California
In the middle of the round circle and air filter, i jut poured som eRegane 2X concentrate down it and now its sitting, will have been 15 minutes by the time i post this. is this the rught way to de-carbon a fuel system, and will it help my scrathy pot wildly moving fuel gauge issue ?
or did it have to be sea foam and not gumout with regane high mileage PEA cleaner
(if smoked a bit and engine idled lower should i go fire it back up and did i so it right, or repeat with seafoam ?
and about the booster vacuum house, idk
I know that most people use either Seafoam or MMO(yes MMO) to decarb an engine, or lastly water injection. Seafoam is a safe bet as that is what its "meant" for.
I'm guessing you mean the throttle-body, yes, you're fine w/what your doing. But, I would scrub it down since you obviously want it cleaned, I notice a more responsive throttle after cleaning mine as it gets sticky w/carbon build-up. Just remove your air cleaner/filter box and have at it.
