seafoam experience
yes, i have to say that Gumout Regane Complete Fuel system cleaner gave me a more noticeable improvement than: Redline SI-1, powerfoam, seafoam, or hot water spray.
but hot water spray was 2nd best
I had previously tried spraying the Seafoam using spray bottle in the carb but I did not get the *after soaking* smoke show.
I finally did Seafoam the "correct" way on my lawn mower the week before last. I took a small water bottle, cut it in half, drilled a hole in the cap and stick a small rubber hose in it. Put the other end of the hose in the carb and slowly fed the Seafoam to the mower. At the end, I intentionally stalled it and let it soak for 10 minutes. Removed the plug, dried it using carb cleaner and yanked the rope to expel (if any) liquid in the cylinder. The mower started with lots of smoke and was smoking for quite a while during the mowing. I definitely felt that it was clogging lot less.
This weekend I tried the procedure again. I let it soak longer and when I restarted it, it did NOT smoke at all! This proves that the smoke show come from the carbon cleaning and not from the burning of the Seafoam itself.
I've had similar experience where it seems like the more its cleaning out the more smoke. I too tried a couple times on various cars to run it through soon after a 2nd time with no smoke on 2nd try.
Same story here and on every other vehicle I've used it on (sometimes after 3 or 4 soakings on poorly maintained vehicles).
What about just using Seafoam in your gas tank? Any luck with that? I tried it, but couldn't really detect any noticeable difference in running. On the other hand, I have the same feeling using Techron. I know people rave about these things, but without some sort of scientific measuring and testing it is really hard to know if they actually do anything.
Unless you have carbon or other gunk build up or injector clog, Techron like products are not going to show any changes.
If you are going to use Seafoam in the tank, go for a stronger dose. Seafoam lists maximum concentration of 8 gallon to a can of Seafoam.
- Vikas
I just ran a whole can through the intake on my 3.3L Buick, and it smoked for MILES!. It was really bad for the first mile, you could not see a thing behind you, then it started to lighten up. It took about 5 miles to go away. I'm going to run a 2nd dose, and see if it smokes as bad. I checked the oil though, and its pretty dark after that seafoam... I want to say throttle response is up, but maybe that could be from the new plugs, or air filter.
But gas mileage is up, near 2MPG!. Same roads and driving everyday, i was getting 21.42MPG before, now im getting 23.32 MPG.
dont be afraid to redline it frequently to keep some of that crud from building up as badly.
seafoam rocks, i love to make smokescreens.
Definitely try the 2nd dose, that way we will all know if the first one was just a show or not.
- Vikas
Has anyone ever tried running B12 Chemtool through the brake booster line or has everyone been too afraid to try it?
-Techniker
-Techniker
B12 is mostly solvent. Maybe if you mix some TCW3 with the B12. It will be similar to seafoam.
I've been working on making a home brewed soafoam.
-Techniker
Not sure how that would turn out
B12 is stronger straight than seafoam on carbon, as it is not petroleum based, but acetone, xylene and butane. The down side is it is h3(( on plastics and rubber not diluted. I keep B12 around to clean a carboned plug or part, but am cautious with it around seals diaphrams gaskets etc.... I have been married 23 years, so I am not afraid of much, but I would not try this.
- Vikas
Ran another $9 can of seafoam through the break booster/intake Still a fires worth of smoke came out. It smoked so bad i could not see the road behind me for near a 1/2 mile... It was BAD.. Also i could feel the car surging like it was misfiring for the first 15 secs when i was on the gas. with in 4 miles smoke cleared up, and car runs very well. Again dont know for sure if it made a huge difference like the first time, or not... I know my wallet is $20 lighter for this seafoam.... That just went up in smoke. haha.
Well, now we won't know until you run yet another can through it :-) It could be because Seafoam smoke is nothing but just a show or you have too much carbon which could not be cleaned with a single dose.
- Vikas
My last SF treatment, I bought the new Aerosol can, not the deep creep. Since I have a Van, I removed the engine cover, and Air cleaner and fired a burst into the throttle body engine running, and got a satisfying burst or white smoke in the AP store parking lot. Without the straw it comes out like wasp spray.
I then began to drive toward home. There is a long Hill marked at 25 mph. I was spraying an occasional burst, and started hearing an ugly noise. I realized it was not my engine, but the 4 cylinder Honda with a soda can exhaust behind me and a young kid tailgating me, upset at my 25 mph approach to the hill.
So I gunned the engine and fired a continuous burst of Sea Foam into the TB. At first the engine bogged, but then it roared and I accelerated up the hill, blasting out a Spy Hunter esque cloud behind me. The Honda dissappeared within it.
While I was sitting at the traffic light at the top of the hill, I saw the Honda emerge from the stinky white cloud. The Kids inside were laughing hysterically, and foolishly they aligned their open windows with my tail pipe. So I Blasted them again, but the cloud was disappointedly not as thick. The light turned green, and I quit blowing the white smoke as I accellerated away. Further bursts produced little to no white smoke.
I stopped once at the store on the way home. With the engine Idleing, I removed the vaccuum line to the Map sensor, attached the straw to the can and emptied another 1/8 can into the intake like that. I also used the IAT and EGR vacuum lines. With 1/8 of a can left, I sprayed it strawless into the TB and stalled the engine with it, then sprayed the remaining can into the intake.
I replaced the air cleaner, vacuum lines and engine cover and went grocery shopping. When I restarted it, there was a little white smoke. Not much. I got onto the freeway and gunned it upto about my 95 MPH top speed, and when I got off at the next exit and waiting at the traffic light, I thought my engine had stalled. It was running so smoothly I could not tell it was running.
I'm a believer. I don't know if pouring the can down the brake booster vacuum line would distribute it evenly to all the cylinders. The Aerosol can sprayed into the throat eliminates that factor. I don't know about spraying similar type products down the intake.
Once when my Fuel pump quit, I used a can of TB cleaner to drive the van out of the middle of an intersection. After I replaced the Fuel pump I was getting horrible Mileage, and shortly after got an O2 sensor code. Apparently the TB cleaner destroyed the 02 sensor. Replacing it brought my mileage back to normal.
My Aerosol SeaFoam treatment has not affected my 02 sensor like the can of TB cleaner did.
Once yearly I puour a can in my tank, right before the Holidays when I fly across country for a month and leave the Van sit, but I think the aerosol introduced into the running engine is the most effective way of introduction.
Those kids probably have a higher chance of cancer now and will have respiratory problems before they hit 40. Breathing in all that seafoam can't be good for the body.
Those kids were smoking cigarettes. They had their windows open, they did not need to tailgate me, nor stop next to my exhaust pipe after seeing what happened not 20 seconds before.
Darwin wins again. You won't make me feel bad for their stupidity.
Not trying to make you feel bad... I was trying to point out they were stupid for tailgating with that toxic smoke in their face. I would have pulled over until the smoke cleared.
How were you able to
0) Which Van?
1) drive the van with air cleaner tubing disconnected?
2) does it not have MAF sensor
3) how in the world were you able to spray while driving?
4) does the can have a long flexible tube so that you can have the can with you on the driver seat?
5) If that is the case, it is great! (3M already has a product like that but they charge quite a lot and it is part of their 3-in-1 Fuel System DIY kit package)
- Vikas
