Hello everyone from Greece, first post in this amazing and very educational forum, I'd like to ask the opinion of yours.
My car is a VW Scirocco MK3, with the 1.4L twincharger DI motor. In many ways it should be very similar to the MK5 and MK6 GTI engine except for displacement and supercharger for low rev boost. Stock is 160 hp, now tuned to over 230 hp with the usual stage 1 mods.
I gotta say that my mileage is pretty low and in the 4 years of ownership I did only 34000kms, or 21200 miles, so engine oil changes come naturally every year with 5200 miles OCI. First change was ta 5200 miles from factory oil to Mobil 1 ESP 5w30, from which I heard great reviews. The second change was again the same oil, and for the third and fourth oil change i used Motul X-clean+ 5w30. All these oils have 504/507 vw specifications.
Unfortunately we don't have UOA here so I can't comment on engine wear much. Car is driven hard, broken in per manufacturer's guide, and never had a single problem with it. Since adding half a quart of oil after break in at 1000 miles, never had a visible oil consumption. Always allowing to reach 60 degrees oil temp on trips, and 3 minutes of turbo cooling. 85% off city and 15% city driving.
Do you think I should continue using Motul? I have a concern with intake valve deposits and Motul has 0.61% sulfated ash, is it low enough? Should I benefit from switching to another viscosity or saps? Price isn't a concern, should I continue with 504 spec oils? VW also allows 502 spec oils for fixed intervals for my engine
Also 1 thing I found out that Mobil 1 ESP is SHC oil, while Motul X-clean+ is a true synthetic, as german site of Motul reveals.
Data sheet for X-clean+ 5w30: X-clean+ 5w30
Thank you in advance
