I've been using the Stanadyne cetane boost + lube + gel point reducer, which didn't fare well in that test, so I spiked it with some Stanadyne lube which did ok. The combination made for a quieter running engine, less ticks and clicks, so'll continue using the combination until I find something else. I'll stay with a demulsifier, and will maybe try just a lube and gel point reducer.
