- Joined
- Jul 3, 2023
- Messages
- 6
I started having problems on my boat with fuel delivery, so I replaced fuel filter - it turned out to be very dirty after only 100hrs. I have been using continuously Sta-bil diesel additive only. However, after having diesel on my boat experience periodic fast RPM drop (for about 1 second and only occasionally) even after I changed the main filter (Racor 2 microns), I wondered if I should start adding something that may help dispersing water (Star Tron Enzyme Diesel Treatment?) and maybe help prevent the bacterial growth (Biobor JF, maybe). The question is, can I start mixing these additives in the same tank, or should I burn off the remaining fuel before adding anything new? If I need to empty the tank, it may take a while since I have about 10 gallons in it, and I burn 1/2 gal per hour at 2,000 rpms. Does any body have an experience with that?
Thanks!
Thanks!
