Originally Posted By: imcharlescee
Thanks guys! Gave me a boost of confidence to go right up and change it. Probably will be doing it next week. Just finishing up the exams. I love this forum, I just joined and everyone seems helpful and not jerks.
The only caveat is that if it's never been removed before (or even if it had) these things can be a real PITA to remove because the drain plug washer seizes to the drain bolt and transmission body. I kept on trying on my wife's Civic and couldn't get it off without a 3/8" square head breaker bar and ramps so that I could get enough leverage. I knew it was loose with a loud snap sound; it sounded like something had broken. In the unsuccessful attempts, I had also rounded off the head of the drain bolt. I think pretty much ever Honda/Acura automatic in the past 25 years uses the same drain plug (90081-PX4-003), which requires an 18mm internal diameter washer.
You'll also want to find more info on the exact location, because some of these drain bolts are in the worst possible locations for making a mess - probably designed by some sadistic gnome intent on destroying driveways with used ATF. There may be individual tips for how to make as little mess as possible. Or maybe there's a clear path and you have nothing to worry about.
