I have a 1997 Silverado 5.7 168k miles, that I'm thinking about changing out the fluid with some Maxlife. The transmission fluid change/maintenance is unknown. Don't believe it has a drain plug. So will extract from dip stick and replenish as needed.
Fluid does not smell burnt, but does seem old, and well used. Truck shifts fine.
I've heard it's best not to mess with an older trucks transmission. but it's probably due for some fresh fluid.
