My '87 Corvette (L98 engine, aluminum heads, roller lifters, auto transmission) with 125K miles really needed valve stem seals badly. So, I took things apart and installed a set of roller rocker arms, new valve springs and retainers while I was at it. That got me thinking about when I'll have to tear into the engine again.
I don't drive aggressively nor a lot with this car lately (5K-7K/year). Other than an alternator, A/C compressor, intake manifold coolant leak, and a steering rack, the car's been reliable. The transmission does leak ATF from where the speedometer cable goes into it (I've added AutoRx to see if that'll help). And, of course, all the electrical connectors and other underhood plastic items have become brittle and break easily. Then there's the interior, which never was very good and has only gotten worse over time. And the weatherstripping, the non-functioning power antenna...the list goes on but they're more annoyances than anything mechanically fatal or major.
What are some of the major vulnerabilities of the SBC 350, and when should I expect them to show up? Transmission? Valve job? Your advice, please.
I've been itching to buy a new "fun" car but I know if I get started thinking about projects on this one that I'll be kept busy for awhile (and I'll probably end up learning something and spending less money in the process
