Last month I've been pretty busy working on my relatives and neighbor's cars and used the money earned to finally build my AMD PC that will be replacing my 10 year old Intel PC.
This time I wanted to do a stealth build with an old HP mATX case despite RGB glass side panel cases becoming popular.
New parts:
AMD Ryzen 1300X
MSI B250 MORTAR mATX mobo
8GB Crucial Ballistix RAM 8GB DDR4-2400 (will be upgrading to Corsair Vengeance 16GB DDR4-3000)
Samsung 960EVO 250GB NVMe M.2 SSD
Parts from old PC:
EVGA 1060 GTX 6GB
Corsair RM550 Power Supply
Sandisk 480GB SATA SSD
HP Pavilion Case
Blu-Ray Drive
1TB WD Blue HDD (Personal Drive)
First was to do a couple of case mods. I cut and removed the rear dusty rusty stamped fan grille for a removable fan grille.
I repinned the power button and case led mobo header connecter so it can plug right in.
Installing CPU, RAM, and cooler onto mobo while on the bench (or on top a box on the floor.)
Forgot to plop in the SSD:
Mobo installed in case along with m.2 SSD, power supply and HDD cage. The HP case uses an inverted mobo design so the pictures aren't accidentally taken upside down. PSU cable management is much more difficult since the cables are made long for an ATX case.
Getting the graphics card in. I have to give props to HP for this case design giving full case length for full length video cards. Unfortunately the round 24pin power cable can't be routed under or to the side of the video card so it has to get routed over:
Powered on with the pretty red LED's lit up around the mobo. Sucks I won't be able to see it since I usually have my PC by the right side of my monitor and it's a solid side panel with some vent holes.
Just a HP Pavilion PC.
New parts:
AMD Ryzen 1300X
Parts from old PC:
EVGA 1060 GTX 6GB
HP Pavilion Case
Blu-Ray Drive
