You’re not driving a RWD pickup through 30”’s of snow. SorryI’ve driven my RWD truck and suburban through 30”
You can drive through it in certain conditions. But one things is for sure in snow, bunch of trucks in the ditch. Though, it is tough competition between them, JEEP’s and Subaru’s.I’ve driven my RWD truck and suburban through 30”
On a parking lot? Maybe.You’re not driving a RWD pickup through 30”’s of snow. Sorry
Well, I have seen some impressive car control skills on packed snow with a late 90's Mustang GT on snows (probably with studs) on the highway, he passed 5 of us, holding a 10-15 deg slip angle going 50-55mph! This was northern ontario though, so he has a few more days of practice than most of us, and everywhere is 100 miles away so he has no time for southerners going 30 mph when there's a few snow flakes....I guess it ultimately is most dependent on tires (obviously) but also weight distribution. I know when it snows here Mustangs, Camaros and RWD pickups aren't going anywhere.
Negative camber or a lot of it is not necessarily bad thing. That primarily depends on vehicle. On my BMW maximum value is -1.9, minimum 1.1. Anything below that and car has extreme understeer, while rear end can’t catch up with front.Well, I have seen some impressive car control skills on packed snow with a late 90's Mustang GT on snows (probably with studs) on the highway, he passed 5 of us, holding a 10-15 deg slip angle going 50-55mph! This was northern ontario though, so he has a few more days of practice than most of us, and everywhere is 100 miles away so he has no time for southerners going 30 mph when there's a few snow flakes....
For me, on the highways without big hills, snow tires with FWD or AWD are the same. I want open diffs as well so I can spin up a tire or two without loosing steering or going sideways. For low speed grip in deep snow or on a hilly driveway AWD or 4wd with even all seasons is better than 2wd with snows.
For ice racing a well balanced rwd car beats a fwd, with equal weight, tires, drivers, but no one except that northerner mustang driver can drive that way on a public road for long and not end up in an accident. Of course AWD is a step quicker again, with everything equal.
Also a car with supple suspension and a "straight ahead" wheel alignment does a bit better in the winter as well. Even fwd cars with lots of rear toe in and negative camber can have the back end wandering on roads with patches of ice...
I think we also must have a different perspective on what actually "getting through" it means. My grandfather had Crown Vics. Yeah, he could eventually make his way around but it took a lot of time, effort and control. I still think 4WD/AWD, FWD, RWD in that order is how it generally goes but there are exceptions.
4WD/AWD, FWD, RWD
Tires hands down is the most important factor in snow.
Yup.....Tires tires tires....
I think I like your order better now that I think about it. I think a good AWD system (Honda/Subaru) is the most ideal you can hit dry patches with no issues and some roads as you know are snow covered then there are dry spots. 4WD would be second.This was my choice prior to experiencing this Honda Ridgeline in the snow.
Now I've flipped to
AWD/4WD, FWD, RWD.
Now I've flipped to
AWD/4WD, FWD, RWD.
This has been what I've observed repeatedly over the years. No question about it.I do enjoy the Tyre Review YT videos, and I've actually used the info in them to make some of my tire choices.
However, I don't place a lot of creedence to this particular video the OP posted, only because it's not what I value in "snow" use. The tester in the video is concerned with lap times so he's pushing the envelople, including drifting sideways through all the corners. OK, but how useful is that when driving on the street? You gonna drift your way through a corner with oncoming traffic? You gonna slide sideways on your way home from picking the kids up from school? It's fun to watch, and it's generating the fastest lap times, but it's not really controlling the car in a "safe" manner. He's controlling it at the fringe edge of operation, not safe operation.
Keeping up your speed by drifting around corners means little to me, as I'm more concerned about traction for pulling uphill. When it comes to snow, I want max traction on my drive and steering wheels. Obviously, AWD is the best. But FWD would be an advantage over RWD (presuming it's a front engine car) every time. Traction is a function of two things: coefficient of friction, and weight. To get the most pulling force uphill, having more weight over the drive wheels is a benefit. So FWD (with a front engine car) beats RWD (with a front engine car), assuming all other things are roughly equivilant.
I live in an extremely hilly area; they are numerous and steep in many sections. I've previously had a couple Grand Marquis (RWD) with snow tires, and now both a Taurus and Fustion (FWD) with snow tires, and the FWD cars do FAR better at climbing the hills with less traction loss. I'll take my FWD cars over the RWD cars in my conditions every time. And my 4WD F250 with snow tires is next level.
Camber alone isn't bad, but it does put a small lateral load the contact patch, so with zero toe, the tires are still wasting some grip pushing against each other. Now when actual toe in is added, the tires are pushing against each other more even more and on ice they might be using all their grip even going is a straight line, so the car feels nervous until the rotates a bit and one tire "wins", like in a moderate corner.Negative camber or a lot of it is not necessarily bad thing. That primarily depends on vehicle. On my BMW maximum value is -1.9, minimum 1.1. Anything below that and car has extreme understeer, while rear end can’t catch up with front.
Again, all that depends on how the whole vehicle is designed. You cannot take the rear axle alone without taking into consideration the front axle, weight distribution, driven wheels, % of torque going between front and rear axle if AWD etc.Camber alone isn't bad, but it does put a small lateral load the contact patch, so with zero toe, the tires are still wasting some grip pushing against each other. Now when actual toe in is added, the tires are pushing against each other more even more and on ice they might be using all their grip even going is a straight line, so the car feels nervous until the rotates a bit and one tire "wins", like in a moderate corner.
My previous wagon was at ford's upper limits for rear toe in and negative camber, which is fine on everything in the summer, but in the winter it was nervous, but with patchy black ice alternating with wet pavement, the back end would start jinking around!! Good thing the car has some steering feel and feed back, so you could just use your finger tips on wheel and let it do self correcting mostly, but I quickly got it aligned to my specs of near zero rear toe in and moderate negative camber and it tracked straight in the same conditions. It did rotate better for autocross after that as well but was very predictable and controllable.
Yep, that's similar to the Durango and Grand Cherokee. I have a variable electronic locker in the rear diff too.Audi, BMW (except Haldex, “fake BMW’s”), Meecedes, Subaru, some VW’s etc. all have permanent AWD with mostly 40/60% distribution.
Even FWD based AWD have some % engaged at city speeds. On interstates, at higher speeds, that is irrelevant.
Most subarus sold are 60:40 with their electronic multiplate clutch, with an automatic or CVT, and when slip occurs, to goes to a 50:50 bias.Audi, BMW (except Haldex, “fake BMW’s”), Meecedes, Subaru, some VW’s etc. all have permanent AWD with mostly 40/60% distribution.
