I'm going to clean and re-pack the wheel bearings on my 10,000lb fifth wheel.
I'm looking for a quality wheel bearing grease that readily available.
Will Mobil 1 work well in this application?
Yes, it will work fine. If you don't know what type of grease is currently in the bearing you should clean out the old grease with solvent prior to packing the bearings.
