My son in law was given a generator a Tri fuel Firman - 9400 watts startup power on gas - the prior owner used it once with gasoline about a year ago and once on natural gas since then before getting a whole house unit.
He ran the unit until it stalled - out of gasoline - except there was about 1/4 inch of gasoline left in the bottom - and now it looks rusty.
I told my SIL I would try and see what I can do to save it -
1. Drain the last bit of old rusty gas - is a first step -
Then what??
Dump some oil in the tank and then drain it out?
Then flush it with some fresh gas?
Then see what I can see?
any ideas???
Tri Fuel 7500W Portable Generator Electric Start 120/240V
At FIRMAN, we have the best solutions for your most unexpected moments. So you can worry less and know we always have you covered! The FIRMAN T07571 Tri-Fuel generator is a 9400-watt trifecta — running on gasoline, natural gas, and propane. The T07571 is ready to work whenever you need it, on...
firmanpowerequipment.com
Then what??
any ideas???
