Originally Posted By: Gebo
It's a stumbling surging bog combination under somewhat less than "petal to the metal" acceleration that is most pronounced on a 34 degree upslope between 2000-3100 RPM's.
That's a rough one. Assuming it's okay under hard acceleration and higher RPM it shouldn't be the distributor bushing or pooped coil insulation.... maybe a dead spot in the TPS? Does it smooth out if you wiggle the accelerator pedal? Wait, that I'm making an assumption for no reason. How is it under harder acceleration and higher RPMs? How about just higher RPMs if you downshift?
