I sprayed some tb cleaner and used an old toothbrush while working the throttle. I also sprayed a can through the air intake with the engine running. I had to spray pre map/maf sensor as the ecu would not let me spray tb cleaner directly on the throttle body with the engine running. Any harm in getting the sensor a bit wet? Is removal of the throttle body necessary to do a decent job of cleaning? How does a manual tb cleaning compare to just running some Amsoil PI or Redline S1 through the fuel system? Is a foaming solution such as Seafoam a better alternative?
