Hey there,
I'm thinking about running techron in my 2001 Hyundai Sonata, which is just below 100,000 miles. Is there any risk to using Techron for the first time at this mileage? I've heard sometimes cleaning certain systems at a higher mileage can cause leaks - although I'm not sure if this would be true with the fuel system.
Also, is it true that you should use Techron for two fillups when using for the first time, and that you should change your oil shortly thereafter?
Thanks!
Thanks!
