JHZR2
Staff member
Hello,
Ive seen lots of applications where RTV is used for sealing a differential.
Ive also seen notice where a good long amount of time should be spent allowing the RTV to cure before applying new lube.
Can anone comment on the long-term effects of not letting it cure a "long time" before putting lube in? Im sure that a shop/dealer doesnt wait a long enough amount of time...
What happens? Does it cause the RTV to degrade, or does it put bad stuff in the lube? Id imagine that there could be some solubility of the stuff if not cured...
