RR. Ghost Oil Change Cost
That’s surprisingly reasonable to be honest, when you factor in the volume of oil (11.1 qts), insurance cost, type of vehicle, and the time it probably takes to do one of these (I’m sure they vacuumn them out, and have to be exceedingly careful to not get any dirt or debris on the interior/exterior). What’s more mind blowing are people that spend $125 at the quick lube to do a synthetic oil change on a Pushrod v8.
20 minutes at most.
they have a cutout for the drain plug and top mount cartridge filters
It is and it likely isn’t a 20 minute job. I don’t doubt The mechanical workload is likely 20 minutes but I’d wager double and triple checking everything and making sure to keep the interior/exterior spotless will add some time. I can’t think of many worse customers to have an immediate comeback from than a RR customer.
