44 reviews total. (41) 5 stars. (2) 4 stars. (1) 3 star. If you read all the reviews, note how many times people mention their butt dyno feeling the difference in engine noise.
Great Product
By JPon July 21, 2012
Size Name: 12 Quart (384 Ounces)Verified Purchase
My 2003 Cobra has been running great after this oil change. It's expensive stuff but good insurance on a high performance motor.
CommentWas this review helpful to you?
Yes
No
Report Abuse
10 of 11 people found the following review helpful
Royal Purple. Believing the hype?
By Jaredon September 24, 2012
Royal Purple HPS 5w30 has been a fantastic motor oil in my application. I drive my car sparingly, but when I do drive, it is "spirited" and aggressive. Prior to running the HPS 5w30, I was a long time user of Amsoil and Castrol 0w30 synthetic.
6 quarts of HPS 5w30 later, my Saleen S281 is running quieter than it did on the previous fill of Castrol EDGE SPT. The car feels less sluggish and has a more immediate responsive feeling to throttle input.
1 commentsWas this review helpful to you?
Yes
No
Report Abuse
great oil
By Stephen P Hansonon December 2, 2012
Size Name: 5 Gallon (640 Ounces)Verified Purchase
Used oil anaylsis have shown this oil to give extremely low wear and even after 10K it shows a high TBN (better to resist acids) I would rate this oil excellent for high performance engines and extended OCI's.
Yes
No
Report Abuse
4 of 4 people found the following review helpful
All I have to say is WOW!!!
By Jacek Kaczochaon December 28, 2013
Size Name: 1 Quart, Case of 6Verified Purchase
I've been using Mobil 1, Castrol, Valvoline, etc. but this oil is beyond them all!
Engine runs so much more smoothly, quietly and with much better acceleration and torque. Whoever claims their engine is louder must be hearing voices and should see a specialist! Combine it with a pro oil filter and you won't look back!!!
Yes
No
Report Abuse
3 of 3 people found the following review helpful
LOVE IT
By Michaelon December 14, 2013
Size Name: 1 Quart (32 Ounces)Verified Purchase
Love it...Best oil you can buy. If you love your car, get this oil. You will not be disappointed ...
Yes
No
Report Abuse
7 of 9 people found the following review helpful
made to perform
By busaon September 21, 2012
Royal Purple with the synerlec is the best oil i have ever used .I can tell the difference in horsepower and gas mileage.Both is a little better.i use royal purple oil filter with it for extended oil change.it's also top of the line.just get both your be happy.
Yes
No
Report Abuse
2 of 2 people found the following review helpful
Engine runs much more quietly...
By John L Petrofskion December 19, 2013
This oil makes my car run extremely quiet, a very noteable difference between using non-synthetic oil. Is also one of the best cleaning oils I have used, having a noticeable effect on cleaning the sludge I could see through the oil fill hole. If you love your car and "have" to buy more expensive oil, give this one a try.
Yes
No
Report Abuse
Great Oil!
By Randall W Nelsonon October 14, 2013
Best motor oil used in my Dodge truck 4.7 V-8 to date. Runs quiet & smooth . Got 135,000 miles on it and never add oil between changes.
Yes
No
Report Abuse
HORSEPOWER!!
By alexander Silvaon September 22, 2013
best oil i ever used increased gas mileage and horsepower! once it goes in your engine you wont want anything else in there thats a promise.
Yes
No
Report Abuse
1 of 1 people found the following review helpful
*DO NOT MIX WITH REGULAR Royal Purple. Jeep Grand Cherokee V8. Works Great.
By chasesparkson July 11, 2014
Since I have started doing my own oil changes, I went ahead and opted to spend the few extra dollars and go with Royal Purple products and have had good results. This was my first time using the HPS line. It is awesome so far. Within just a minute of running, my 2004 Jeep Grand Cherokee Limited 4.7L v8 sounded smoother and quieter. I paired the Oil with a K&N HP2004 oil filter and a K&N Air Filter. The results are great.
******I would like to add, I didn't buy enough and was about 1/2 quart short. I called Royal Purple and asked if I could mix HPS with regular Royal Purple to top off the rest because I had some regular left over and HPS is hard to get in stores. They said that mixing the HPS line with regular Royal Purple was definitely not recommended. The additives are different in both and mixing would cause the positive effects of the HPS oil to become weakened due to certain additives "canceling out" others and may also cause too much of certain additives. So DO NOT MIX WITH REGULAR ROYAL PURPLE OIL. I couldn't find anything on this on my search before calling, so Just a "Heads-Up"! My 2004 Jeep Grand Cherokee Limited 4.7L took 6 1/2 Quarts to get the oil to be in the "Safe Zone" on the oil stick on flat ground while running despite that online says 5 quarts in some places... always go by the stick and buy enough oil.
Yes
No
Report Abuse
Royal Purple Engine Oil HPS
By SanyaSon January 20, 2014
Will always use this oil for all my cars. It's a bit pricey but is worth it in the long run, and buying a box of oil at once comes out to be cheaper. Saves you a trip to the store with every oil change.
Yes
No
Report Abuse
Royal purple is the best
By Lindsay H.on October 6, 2013
Royal purple pile is the only oil I use in all of my vehicles. It is the best oil on the market. I autocross the vehicle that I put this oil in and have had no problems like other with the same car that uses conventional oil.
Yes
No
Report Abuse
Great oil for my BMW
By Ian Workmanon August 30, 2013
I purchased Royal Purple HPS 5w30 for my initial oil change for my 2013 BMW 335is over the performance BMW oil. It has been doing wonderfully on my daily drives to and from work along with pushing 100 to 130 mph. I will be purchasing more and continue to use this product.
Yes
No
Report Abuse
Best Sythetic Oil
By Jackon July 6, 2013
I use this in all my cars and have taken two of them over 200k miles with one having over 260K.
Yes
No
Report Abuse
Excellent Product. Highly recommend for car enthutheist who want the best for their engine.
By Slappon May 23, 2013
Great product! After 2 days of driving I've noticed smoother starts, acceleration and better gas mileage! I will use this product always in all of my vehicles.
Yes
No
Report Abuse
The best stuff
By Jimmyon May 9, 2013
I recently bought a 01 lexus es 300 with 145000 miles on it, started out using 5w30 royal purple and did my research and found that the HPS has the synerlec that you need.The only issue is right now I cant find it anywhere except Amazon which is not a bad thing because it is still cheaper than the regular 5w30 if you buy it by the case.My car is smoother and quiter and I am getting about 2-3 miles more to the gallon on gas.I will be changing the filter this weekend but not the oil.The oil can go to 10k and Im at 7k.Read all of the hype then try it I bet you will stick to Royal Purple, I am.
Yes
No
Report Abuse
3 of 4 people found the following review helpful
The Best Synthetic Oil for ALL vehicles!
By Adam Pitton June 27, 2013
I gave this a 5 Star rating because in my opinion, Royal Purple High Performance is the best synthetic motor oil available today. I have replaced the junk they put in my mom's Infiniti with Royal Purple and she says she is getting better performance from her car. I also replaced whatever synthetic oil they had in the new Chevrolet Corvette (2013) that I recently purchased, with Royal Purple HP Synthetic Motor Oil and am very pleased with the way my car performs, too. I recommend Royal Purple to all of my friends and car "nuts" and several have changed theirs to Royal Purple and are amazed with the positive difference in their cars. That is why I have rated this oil so highly.
Yes
No
Report Abuse
Big Difference
By Lloyd Nicholason May 19, 2013
Maybe it's my imagination but my truck (03 Tundra w/160000 mi) seems to be running better and quieter. I have used Royal purple before and it worked fine but the HPS seems to make a big difference.
Yes
No
Report Abuse
Royal Purple HPS vs Pentosin
By YPon August 31, 2014
Great product, I use it on my 2006 Audi A6 Quattro.
Even though it's not on the list of oils recommended by the factory but I feel like this one is way better than recommended Pentosin. I used Royal Purple HPS 5w30 all the time until recently I tried to use recommended Pentosin which was 5W-40. It was right before spring began.
One note is that my Audi burns oil and it's been acknowledged by the Audi itself to add 1 quart every 6K miles, that's how they work and nothing you can do about it.
When I used Royal Purple HPS, my dash would warn me of minimum level and to add oil, one time or sometimes never during the 10K miles interval.
Fast forward to Pentosin, I got warned twice during 10K miles interval. I had to add oil twice.
With Pentosin I drove only to school, about 15 miles a day in normal conditions (no mountains) in Washington state and I can remember only one 4 hour trip to Oregon (some mountains).
With Royal Purple HPS I drove around the whole country, literally. Just to give an idea, I drove from Washington to Minnesota and Missouri in winter, Florida in Summer, Cali in fall and when coming back, sometimes I used different routes.
That includes driving through Washington, Idaho, Oregon, Montana, Utah, Cali, Georgia, Tennessee mountains, Midwest plains; Florida and Midwest hot summers; and also Minnesota, North and South Dakota winters where temperatures reached 6 degrees. Also to mention that I drove many times to mountains in Washington state in winter, hot desert in summers and constant Washington rain throughout the year.
Looking back, Royal Purple always served well to me and my car. I never realized that until I tried to use Pentosin in my car.
Yes
No
Report Abuse
Bow down the king
By ferrarion August 22, 2014
First time user and very satisfied quick background is I own a 09 chevy impala 3.5 v-6 bought it brand new. I been hearing a lot of talk over different toils over the last couple years as they change. Royal purple which seems to be the cats tail of oils I did a lot of research on and settled on buying hps. I previously used pennzoil for about a month but it made my car roar especially during winter in New York. So I switched to Mobil 1 synthetic oil and I very satisfyed but concerned that it's not lasting a long as I would like it to so I just recently put in royal purple after 6000 miles on Mobil 1. After driving with royal purple I notice that my car is super super quite like its a hybrid. Also I can see a small difference in how smooth the engine runs compared to before but I don't notice a difference is the mileage mpg so maybe in time. But in my onion the royal purple is totally worth the money and can save you money. Take the challenge and try the royal purple you will be really happy. Thank you RP.
Yes
No
Report Abuse
Simply the Best Motor Oil
By Surfoneon September 15, 2014
Royal Purple is the best oil for high temperature running engines and around town driving. add the HPS formula and you have the added benefit of greater protection for those engines having close tolerances between rings and cylinder surfaces. I have 40,000 miles on a 2006 G-35 Infiniti. This car runs like it did the first day I bought it. I punch it at least once a day to keep the spirit alive as it were and this always brings a smile to my face along with a gorgeous exhaust note. Premium gas and great oil from Royal Purple...!!
Yes
No
Report Abuse
4 of 6 people found the following review helpful
The Best Oil
By STBon July 13, 2012
Royal Purple is much better than I thought. You can't go wrong purchasing this product. I am getting better gas mileage on my Nissan Titan truck.
Yes
No
Report Abuse
i do belive that 5000 miles is a good first turnover
By Orlandoon September 9, 2014
Outstanding products. Always high quility. Packaged well and delivered on time. As expected from Royal Purple, no issues while I switched from conventional to this synthetic. Synthetics are rated for much more than 3000 miles between oil changes, was able to get 5000 before my 4Runner was asking me for an oil change. This being my first oil change between conventional and synthetic, i do belive that 5000 miles is a good first turnover. Will definately be buying again from now on.
Yes
No
Report Abuse
2 of 3 people found the following review helpful
Sweet purple necture.
By stroobyon June 1, 2012
Excellent oil. Holds up to any punishment I've thrown at it. Really like the color too. The 5 gallon size is perfect for me (car takes 2.5 gallons per change).
Only thing bad I could say is that if you do not have an oil jug to poor into; this size would be very difficult to use.
Yes
No
Report Abuse
This is a good product at a good price but it is easy ...
By Robert Cruderon July 17, 2014
Fast delivery. The engine is quieter but have not yet seen a difference in power or mileage. The original problem was cam bearing galling and seizure in less than 5000 miles after a rebuild on a very cold morning. If the problem is specific to the failed head I may never know if the HPS has helped. This is a good product at a good price but it is easy to succumb to the placebo effect when switching to a different oil.
Yes
No
Report Abuse
Skeptic turned Believer
By Brent Son September 1, 2014
Put in an 02 Silverado and immediately the truck ran smoother and was NOTICEABLY quieter as many other reviews stated. My wife even commented on the reduce decibels. Power seems as good or a bit better. I know from reading comparisons online that the protection is much improved over 95% of all other brands. More money for it but I am ok with that as you can tell a difference as soon as you fire it up!
Yes
No
Report Abuse
Best oil, period.
By Alexis Padillaon July 11, 2014
I have been using RP synthetic oil in all of my cars since new. The best oil I have ever used. This was my first time using HPS and although I do not feel any difference between it and the RP API certified, the extra zinc protection is a good insurance.
Yes
No
Report Abuse
Fantastic oil. Really protects my car's engine
By Scott G.on July 8, 2014
Fantastic oil. Really protects my car's engine.
Yes
No
Report Abuse
Five Stars
By Bmxsnowildon July 3, 2014
strangely I have gotten better MPG since I started using this oil....
Yes
No
and on and on!
Great Product
Yes
No
Report Abuse
Yes
No
Report Abuse
great oil
Yes
No
Report Abuse
Yes
No
Report Abuse
LOVE IT
Yes
No
Report Abuse
made to perform
Yes
No
Report Abuse
Yes
No
Report Abuse
Great Oil!
Yes
No
Report Abuse
HORSEPOWER!!
Yes
No
Report Abuse
Yes
No
Report Abuse
Yes
No
Report Abuse
Yes
No
Report Abuse
Yes
No
Report Abuse
Best Sythetic Oil
Yes
No
Report Abuse
Yes
No
Report Abuse
The best stuff
Yes
No
Report Abuse
Yes
No
Report Abuse
Big Difference
Yes
No
Report Abuse
Yes
No
Report Abuse
Bow down the king
Yes
No
Report Abuse
Yes
No
Report Abuse
The Best Oil
Yes
No
Report Abuse
Yes
No
Report Abuse
Yes
No
Report Abuse
Yes
No
Report Abuse
Yes
No
Report Abuse
Best oil, period.
Yes
No
Report Abuse
Yes
No
Report Abuse
Five Stars
Yes
No
and on and on!
