Royal Purple formula change
pbm
New York
As you can see from the PQIA data, there has been a change in Royal Purple's formula. One version is the high sodium version similar to Valvoline Synpower and the other (newer version, I think) is a high Boron formula with moly. (which seems to be a better formula, IMO.) Does anybody know when this change happened? Does anybody know how to read the date code on Royal Purple bottles? I ask because I picked up several bottles of 10w30 on 'Clearance' at AA. I would prefer not to mix the high sodium (no moly or boron) formula with the moly/boron (no sodium) formula. Thanks. http://pqiadata.org/RoyalPurple5W20.html http://pqiadata.org/Royal_Purple_5W20.html
I agree that the formula change you mentioned is for the better. I don't know when the formula changed though and I don't know about the date codes. Thank you for the information.
I believe you have it backwards. The higher moly/boron formula was purchased in 2016 while the higher sodium/synpower-esque formula was purchased in 2017. Between that and the recent UOAs posted with RP, it is safe to assume that any API certified RP purchased today will be the higher sodium formula that mirrors Valvoline SynPower. To get a high moly, low sodium formula of RP you have to purchase the non-API certified HMX or HPS line.
I know that the high sodium formula was purchased after the moly/boron formula but I think the moly/boron is the newest formula. Here's an RP 5w30 sample from 2013 which is the high sodium formula that I remember as an RP trait. http://www.pqiamerica.com/March2013PCMO/roylprp.htm I think I'll call or e-mail RP tomorrow and get it straight from the horses mouth....I'll keep you guys posted.
Here's a UOA posted by c5z06 two days ago running RP 5W-30 in his Colorado and it shows 4 ppm Moly and 5 ppm Boron with their nice dose of Sodium at 349 ppm. c5z06's UOA
I contacted RP but didn't get much out of them. They couldn't tell me which was the older product (didn't seem to know anything about the formula being changed).
