What causes circular grooving around rotors? Is it hard spots in the pads or weak spots in the rotors or both?
2 scenarios:
I have a 07 Honda odyssey that at 190k I finally had to replace the front rotors and put on Oreilly's brake best rotors with Honda pads. now with 250k those rotors are still flat as new as the pads are nearing replacement again. I actually expected these to wear faster and more uneven than the OEM rotors, but to my surprise they have not and outside of being darker from pad material show litte noticeable wear.
I also have a 06 Buick, it has Oreilly brake best select rotors and ceramic pads on the front and after 50-60k, the rotors have grooves like a record worn around them. There is still pad left, but its starting to pulse so they will be getting swapped soon.
Since both vehicles are the same rotor line, I am guessing this is a pad issue related to the brake best line? I've wondered if the ceramic formula isn't as evenly mixed and leads to hard spots in the pad?
I am switching the Buick to Raybestos element 3 pads and rotors to see what happens both front and rear. Typically Ive ran oreilly or advance pads premium pads because when I needed them I needed them in a hurry and for the most part haven't had problems with brake function just curious why they wear like this.
2 scenarios:
