Originally Posted By: WishIhadatruck
Originally Posted By: JAG
If the high AL is possibly from detonation, increasing oil viscosity beyond this already reasonably oil is not the solution. Higher octane gasoline, insuring piston tops and valves are not overly carboned, and using good spark plugs of right heat range are some solutions for detonation.
Unless its scuffing or oil film break-down on the piston skirts.
If there was piston scuffing, would you expect iron wear to go up as well?
Originally Posted By: addyguy
What did yo re-fill with? Sorry if I missed it......
I refilled with more of the same, Rotella T 10W-30. I have enough in stock to do one more change.
Well, aluminum is softer than iron
I dunno, just throwing ideas out there. Unless you tear it down, you aren't really going to know anyways.
