Roof Repair - found a good guy
Canuck - moved to —> California —> Texas —> ???
A portion of the roof on my rental property needed to be repaired late last year.
I called around some companies and many would not ever return my calls or reply to my messages. Got tired of this and looked at my local FB market place. Yes I know there are tons of scammers out there, fortunately I can smell BS pretty quickly.
Finally found a guy, talked to him over the phone and he came over to assess the situation. I already knew the plywood underneath has rotten away as I went up in the attic to investigate beforehand. He went up on the roof and pretty much immediately identified the trouble spot. At that point I knew this was my guy.
He also found another soft spot above the main one that I missed and repaired it as well.
Here is his work, pretty much indistinguishable from the rest of the roof. No leaks so far 9 months later.
one of our local Roofing contractors always says in his commercials, " if you call us, We'll call you back" which always stuck me as odd, but...
Nice looking shingles. Are they extra thick laminated shingles?
No idea, I have no clue about shingles.
The plywood deterioration is next to the exhaust fan vent. Wonder if there is a relation?
The roofer said the vent wasn't sealed properly there. The big hole didn't have anything protruding from the roof, so it was likely poorly sealed and a low spot where water collected.
First time I have seen metal baffles. I have seen a lot of those baffles made of cardboard used with blown in insulation..
OSB on a roof???
It passes code! But isn't a great idea for roofs or floors as it can swell with water or even dampness and I think its not nearly as rot proof as most plywood. I seen it swelled and curled up at the edges of the sheets on a new roof in a couple years, but probably there's lots of subdivision houses being built with it. Probably better OSB now I would hope.
