A machinist on a motorcycle-specific forum posted the following:
However, it is abundantly evident that many motorcycles shear the heck out of oil. I've usually attributed this shearing to the transmission gears in the shared sump design of most motorcycles, and secondarily to the high RPMs possible.
So, are roller bearings really the great shearers of motorcycle oil, not transmission gears? Do they actually spew ferrous debris into the oil at a significantly greater rate than plain bearings, becoming the limiting factor in OCI length?
Both suppositions (roller bearings cause greater shear than plain bearings, and roller bearings produce greater wear metals) are new to me. Frankly, I don't see support for the latter in the UOAs over in the motorcycle UOA forum.quote:
I think there are two basic issues. First, the oil shears down very rapidly with a KLR. Roller bearing cranks are much harder on oil than conventional bearings. It's been quite awhile ago, but testing on a KZ1000 sheared down from 50wt. to 40wt. in only 800 miles. That was with Kaw oil, which was then made by Sunoco IIRC. Synthetics would be better here.
Second, is the ferrious metal debris which gets very high. The filter won't catch it. A magnetic drain plug helps, but won't get it all. Roller bearing cranks generate more of this stuff. I would not run even the best oils over 2000 miles. No matter how good that oil is, the fine metal debris will slowly chew things and wear them out. One cam at over 200.00 will buy a lot of oil.
