No. Was planning on just doing the manifold gasket, then step after step needed to dig deeper. I'm just planning on pulling it, that way I can get measurements, find the root of the problem, and address it accordingly. Motors known to drop vale seats, and warpage due to overheat, aluminum heads, spin the 8cyl rod bearing, timing chain guides going & some reports of oil pump failure.
The inside of the timing chain cover was eroded and I had to replace it. Not sure what happened there. This is a interference motor, so maybe a valve came into contact w a piston. We will see.
