Just looking for some advice from anyone who has dealt with these engines before. I can't seem to get many of my questions answered clearly. I have the engine out of my husband's Regal GS s/c 3800 L67, 169k. We have had this car for a while and have put around 3k miles on it since we bought it. It doesn't have the typical 3800 rod knock, it barely made any noise at all honestly. But I have it out to get the water pump done and replace gaskets, timing chain and oil pump to get it to stop making a mess. No smoke or oil use really, ran perfectly smooth, power was great, etc. The intake gaskets were done as soon as I got it home, so there is no coolant in the oil. Not sure what happened to it before me though. The gaskets sure weren't fresh and it seems that it has stop leak in the cooling system that I have flushed out, that uncovered a radiator leak .What I would notice sometimes is that when hot, and I would pull away from, say, a stop sign. I could hear a rhythmic thump. It wasn't the typical tap from say a rod knock or bad lifter. It almost sounds like someone repeatedly hitting a low note on a xylophone honestly. But this was only like 3 thumps and it would go away. No noise on harder acceleration and none on deceleration or when cruising. It wasn't always, but I did notice it since I am really sensitive to things like that. Most people honestly would just say the engine is silent because 99.9% of the time it truly is. I had some VW diesels that made a similar sound, but it was normal on those haha.
Basically I have the engine out and the oil pan off and there is some metal in the pan, some flakes (non ferrous). Obviously something is going on and I obviously DID hear a little something. Others have told me I am worrying too much, but I prefer to fix it before it sends a rod through the block, if that is what needs to happen. Now my problem is: can I check on the bearings? Do I just do the gaskets and put it back to see how much further it goes? Everything I have read says that the rod bolts and main bearing cap bolts are tty. So basically I can't check on them otherwise I will need to get the block align honed and obviously that goes along with a full rebuild which I am trying to avoid if possible. Just not good timing for that kind of expense right now. Also can't seem to find the rod bolts which surprises me if they have to be replaced if touched. Only ARP studs and bolts that require machining.
I have seen many posts that say just slap some bearings in and reuse the hardware, or I get the typical, the world will end if you don't get a full rebuild with 10k in top quality racing parts. This is just a weekend toy and I do hope to get it maybe fully rebuilt at some point and do some mild mods. This just isn't the time for that. Another option is just to get a used motor that seems to run fine. Then hoping I don't end up with the same problem since these all usually suffer from the gasket failures and getting the coolant in the bottom end, tearing up bearings. Really would be easier if I could just pop the caps off and check the bearings with plastigauge and see where I am at. There is some side play in the rods but it seems even and fairly normal. Haven't had a chance to check it for closeness to spec. But there is no play in the rod bearings themselves. At least not enough to make them move at all in any other direction than directly side to side against the neighboring rod. I am thinking it may be a main bearing, worked on a Taurus once back in the day that made a similar noise, just a lot louder and it was the main bearings in that 3.8 . Any advice on this would be appreciated. Wondering if I should just slap it back together so at least the car is movable and put it off for another time. It did run perfectly aside from that noise I heard occasionally.
Thanks in advance guys, I know many of you have had experience with these engines in a variety of cars so I hope someone will help me make a decision one way or the other. I got the car for next to nothing so I don't mind dabbling with it, just not a full on several thousand dollar rebuild right now. Need it either fixed or movable at this point. I will also see if I can get some pics of the metal, not sure how well they will show up.
