I was asked about this failure with no crank journal damage I'd mentioned on another post. This my wife's '76 MG Midget-bought new when we needed another car and there was about zero 'out there' at that date that interested me. So she's the driver and loves this 'cute' little red roller skate-a new car with old technology. Move forward about 20 years (around 35k miles)and I notice one day that hot idle oil presure is down a few pounds from normal. I rarely drove this car and it could have been this way for some time as wifey wouldn't likely notice a few pounds on the Smiths gauge. No other indications/noises. The pan is easy to drop on these and with only three main bearings, I was always a bit leary of this engine anyway. There was some of the usual leaded fuel gray slurry in the pan, but nothing else of note. I started removing rod caps-inspecting/plasigauging/replacing caps one at a time and all was well and the same with mains until the last=rear main. The cap came off and the back of the bearing shell was blue=heat and about 'fused' to the crank jounal-more than oil 'stiction'. I got it loose and it 'popped' out. The bearing was now deformed with the half shell trying to make more of a circle. The upper shell was more 'normal' but both showed heavy wear, nearly down to the backing. Surprising to me that the journal was just fine. These engines use separate thrust bearings and they were also a bit out of spec. Anyway, I replaced all that and it's been ok since. I suspected that there may be some misalignment with the trans input shaft and crank pilot bearing, but frankly not sure. This has been run on Rotella 5-40 since it became available, but conventional 10w30 Havoline in the early years. So that's the story-we watch the gauge pretty close now!
