Originally Posted By: Nate1979
Originally Posted By: Plawan
4th
Originally Posted By: goodtimes
Are you sure the MG adbv was working fine? It should be able to push in through the baseplate holes. This one does not. Here is the picture of the filter as it would exist inside the canister. The adbv does not function unless it raises from the baseplate, which would allow oil to flow past unfiltered. The neck on the end cap is too short with the concave baseplate:
Here are a couple more of the filter:
I must say that is an intresting and great looking filter.
Looks very solid. Is it one of those full synthetic medias too.i spent some time researching it but still am not sure of the media type. It does list a micron rating of 2.
Atleast this mg is more than just a full flow filter as well. Definatley overkill but the gent earlier was rifht. If the filter that can filter the most and smallest particles is the holey grail in filters around here, seems like yall ought to be ecstatic about this one.
No, not a Micron rating of 2. It has a bypass filter section that can remove particles as small as 2. This is nothing too special.
They claim 2 micron in the bypass.
http://www.microgreenfilter.com/faqs
The fram ultra doest have a bypass so it doesn't come close.
Its an excellent single stage filter (thats why I run it) maybe the best (debatable) - but its not the equivalent of any true 2 stage design.
