Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 3,622
Overrated along with brain cells.And liver cells.![]()
I've heard the bulk of these cruise ships described much the same way. 3,000+ people packed into a waterproof metal tank for days on end. All rubbing butts and elbows.
Think about it. You're carrying around a plastic bottle of warm water all day, with plenty of your oral backwash in it. What could possibly cause bacteria? I change my dogs water at least 5 or 6 times a day.
Right...kind of like stating plates that are not cleaned well between meals are dirtier than ones that get cleaner. Just clean the plate.I use a water bottle for exercise, wash it out every time. Not difficult in any way.
I use a larger Stanley thermos for ice water. Also wash it out after use.
Go look at what actually ends up in bottled water. phthalates, heavy metals, micro plastics. Our water authority publishes a report yearly on water quality you can go read. Its done by an independent third party and our water authority is a separately run non profit owned by the county, so there is no incentive to lie. I'll stick with my tap water. My immune system can fend off bacteria. It can't do much with lead and microplastics.In regards to the environment only, is it better to use a re-usable bottle that you wash everyday with hot, soapy water or just recycle the plastic water bottles daily? I use a Contigo stainless steel re-usable bottle that I really like but I do wonder if I'm having a positive or negative effect on the world in which we live. I wonder the same thing every time I line a sheet pan with aluminum foil so cleanup is easy. Better to wash the pan or throw a ball of foil in the trash?
