Originally Posted By: whip
I've had many cars go over 200,000 miles. The engine was never a problem, and always on conventional oil. I don't see a need to use synthetic oil to increase the engine life.
I've never bought a new vehicle. My 99 silverado had 50000kms when I bought it,the 4V in my mustang has 30000kms. These are the newest engines I've ever owned(I have a built 306 going into the Capri. It has 0kms) and the only issue I've ever had was an 83 cutlass with a 305 suffered the soft cam issue accelerated by using restore( I was 17,I didn't know it was junk)at every oil change which clogged my filters sending the unit into by-pass accelerating wear,and my air filter housing I flipped the cap upside down so it completely exposed the filter element,which I'm sure was allowing gravel into the combustion chambers.
I dropped a 350 in it,a posi unit with 3.73s and that car became an animal.
Anyways what I'm getting to is I've had vehicles with over 400000kms and the engines were still decent but suspension,brakes,tie rod ends etc ended up sending them to scrap,not the engines.
I've got 3 full size work vans. 2 fords. 1 with a 351,and 1 with the 4.9 straight 6. The 351 has 350000kms,the 6er has 300000. Both were bought used and were used as work vehicles,fully loaded since they rolled off the line. Neither consume a drop of oil and run like a dream.
The other is a chev with a 305. Its got 480000kms on the original engine. It too was bought used from a plumbing and heating contractor so it was fully loaded since new as well. Its just starting to burn some oil between oil changes,about 1 quart per 5000kmsish or so.
I use the Pennzoil conventional jugs I bought on sale in those vans(had 30 jugs)for 12 bucks a jug. They all are basically city driven. Rarely highway use.
Once I use up my stock they will get the supertech 5 gallon pail oil that costs 45 bucks per 5 gallon pail.
All these vans have been work vans their entire existence. They were beaten on by employees,maintenance was sporadic yet they keep on rolling.
Then I've got 2 cube vans. Both fords. 1 with a 7.3 the other a 5.8. Again they were loaded their entire lives. The 7.3 has 500000kms and will start in -30 without being plugged in. The 5.8 has 450000 on it. Engine still runs great but the front end has pretty much had it so it goes from site to site and stays on site.
What I'm getting at is engines will usually outlive the body even with poor maintenance and all the money spent on PM could just be a waste considering the lifespan of the other components.
Just spitballing
