I get these flip key shells on Ebay for about $10. You take the guts of the factory remotes and put them in the shell as well as a transponder chip which is another buck or two. If you pry out the chip from your original key and use that, you won't even need to program anything. Finally, get the keyblade cut. One less thing to carry in your pocket and no pointy key to jab your leg.
