New injectors, wiring harness, coils. Cleaned ground and all connectors. Same issue. Injector circuit open, Cyl 1. And now a Cyl 1 misfire. Not sure what to do now but I might as well throw a new pcm at it at this point.
You need to ohm check between the injector and PCM then find the break and repair it and verify that the injector circuit at the PCM is in fact making switched ground output. Could have a dead injector driver. Probably verify the injector driver is making output first, no sense digging in a harness to find nothing.New injectors, wiring harness, coils. Cleaned ground and all connectors. Same issue. Injector circuit open, Cyl 1. And now a Cyl 1 misfire. Not sure what to do now but I might as well throw a new pcm at it at this point.
I was thinking that! The converters are brand new.May have shaved some miles off that converter though...
Fixed that for you LOL, that's what warranties are for!I was thinking that! The converters were brand new.
