Love’em or hate’em, if your Tire Pressure Monitor sensors crap out you can put a bit of electrical tape on your dash light and carry on or you can replace the the sensors. My son and I forgot to have new sensors installed on his 2010 Silverado last time he bought new tires and at least one sensor crapped out with two years left on two tires and maybe a year left on the other two. We decided we wanted to rotate the tires anyway, so we decided to throw in new sensors. We have a local Indy mechanic with a full on air powered tire changing machine who said he’d change them if we brought the new sensors and the tires on rims but off the truck.
I had purchased these 315 MHz sensors from Amazon. Attached is a photo of the page. After we received them, We went to work jacking up the rear of the truck at the diff, and putting up some jack stands. We removed the rear tires, loaded them in my Ford Taurus and took them a few miles to Phil, the mechanic. Phil doesn’t like to take short cuts so he marked the air inflation valve and took the tires completely off the rims. He pulled off the old sensors and installed the new ones and put the balancing weights back on. Another part of the deal is Phil didn’t have to mess with programming them: that part was up to us.
Phil was done in no time, and we took the tires back home and installed one tire on the front. ( Recall I was rotating them). I had set the rear axle on the jack stands and moved the jack to the front. After installing the one tire, I jacked up the other side and pulled the wheel, leaving the jack and a jack stand at the corner. I then took the front tires to Phil. He worked his magic and charged us a total of $28 for all four. Then we brought them back, finished putting a rear tire on the front and placing the original fronts on the back.
