Replaced few parts, car still producing cam code
Winnipeg, Canada
So posted before about my 04 Golf having starting problems in the mornings. We ran the VAGCOM on it and produced the codes seen in the first quotations. The 2nd quotation is the new VAGCOM reading after the repairs.
We did a ground wire repair that was in TSB by VW if those codes were present, replaced the ignition coil, and replaced the spark plug wires. While the repairs got rid of some codes, some still remained. Just wondering if I should now be replacing the cam sensor automatically?
Thanks for any help!!
Quote:
Sunday,12,June,2016,11:39:56:64845
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: 9BWGL21J044000688 License Plate: FPC-486
Mileage: 196540km-122124mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWGL21J044000688 Mileage: 196540km-122124miles
Address 01: Engine Labels: 06A-906-032-BEV1.clb
Part No: 06A 906 032 MT
Component: 2l LEV2 A4 MQ5 G 5275
Coding: 00001
Shop #: WSC 00000
VCID: 7CF90CCB6C162ADE37-513C
9BWGL21J044000688 VWZ7Z0C7632736
7 Faults Found:
17746 - Camshaft Position Sensor (G40)
P1338 - 35-00 - Open or Short to Plus
17763 - Cylinder 1 Ignition Circuit
P1355 - 35-00 - Open Circuit
17769 - Cylinder 3 Ignition Circuit
P1361 - 35-00 - Open Circuit
17772 - Cylinder 4 Ignition Circuit
P1364 - 35-10 - Open Circuit - Intermittent
17766 - Cylinder 2 Ignition Circuit
P1358 - 35-10 - Open Circuit - Intermittent
18613 - Performance Malfunction in Cooling System
P2181 - 35-00 -
16840 - EVAP System
P0456 - 35-10 - Very Small Leak Detected - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000 785 00200
VCID: 336BE7F751C825A6A6-5120
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1M AIRBAG VW51 02 0008
Coding: 12621
Shop #: WSC 00000
VCID: 224512B3AE32BC2E5D-5120
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 807
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 15332
Shop #: WSC 00000
VCID: 65CF49AFFF9C8B16F8-5102
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: 70E128FB305E5EBE9B-5120
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00000
VCID: 3773D3E715B0C9869A-4B00
Subsystem 1 - Part No: 1C1959801A
Component: 8C Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8C Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 8C Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 8C Tõrsteuer.HR KLO 0009
1 Fault Found:
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
Quote:
Wednesday,02,November,2016,18:07:30:64845
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
Mileage: 201800km-125392mi Repair Order:
76
VIN: 9BWGL21J044000688 Mileage: 201800km-125392miles
Coding: 00001
Shop #: WSC 00000
VCID: 7CF90CCB6C162AA2E0-513C
2 Faults Found:
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0100
Coding: 0004097
VCID: 336BE7F751C825DA71-513C
Coding: 12621
Shop #: WSC 00000
VCID: 224512B3AE32BC528A-5102
2 Faults Found:
Coding: 15332
Shop #: WSC 00000
VCID: 65CF49AFFF9C8B6A2F-5120
1 Fault Found:
01304 - Radio
Coding: 00006
Shop #: WSC 00000
VCID: 70E128FB305E5EC24C-5102
1 Fault Found:
01304 - Radio
Coding: 00258
Shop #: WSC 00000
VCID: 3773D3E715B0C9FA4D-4B00
2 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
According to your Vag-Com it looks like you need to replace the camshaft position sensor.
I'd start there.
You need to scope it. Lots of things will give you false bad cam sensor codes. Like an alternator with a bad diode. People telling you to replace something blindly just because a code is set should delete their accounts.
Oh come off it. He has a very specific fault code, displayed by VCDS. It's not like we're chasing P codes here, buddy.
I'd love to hear your explanation of how a bad diode in a 2.slow's alternator will throw a G40 sensor fault.
+2 that would be my next step also.
I agree. The code only tells you where to look, and it could be a wiring issue.
I think we can see who works on Volkswagen vehicles here and who puts a screw driver to the valve cover and makes an assessment.
For a VAG error code 17746:
17746/P1338/004920 - Camshaft Position Sensor (G40): Open or Short to Plus
Malfunction Indicator Lamp (MIL) active
Possible Causes:
Camshaft Position Sensor (G40) faulty
Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
Possible Solutions:
Check Camshaft Adjustment
Check Camshaft Position Sensor (G40)
Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
I guess Volkswagen forgot to add that the alternator diode is on the same circuitry that trips this error code.
I'll be watching for a drop in member accounts after this error code is resolved.
Those that live by the by the code die by the code.
Originally Posted By: CKN
Throw parts at it...that's the BITOG way!
Ok smart guy, what would you do?
We're all waiting for your sage advice.
I personally think that KingCake(post above) is on the right track! That's my sage advice.
IIRC from his previous post on this he replaced a few parts already and did some wiring mod and checked the harness. The cam code seems to be persistent and not knowing if he has access to the diagnostic tools having some one hook up test equipment may well cost more than changing a $50 sensor (Rock Bosch OE) so changing it is not all that unreasonable either on an engine with over 120K on it.
I am no advocate of throwing parts at anything but sometimes if its not that expensive a part and for some reason is difficult to test properly (or you dont have the equipment) and it looks like duck and quacks like a duck well you get it.
You don't spend all day tearing into the wiring harness and checking it because a headlight is out, replace the bulb first.
I don't get the connection to a bad alternator diode, he doesn't complain of flickering lights and the battery going dead. Its easy enough to test with a DVM set on low AC volts.
