2004 Golf 2.0, still putting up ignition codes....
Winnipeg, Canada
So posted a while back about troubles my car was having with codes and bad startups. Im now thinking it might be an ignition coil problem. What do you guys think?
https://bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/4218602/gonew/1/Need_to_do_electrical_repair,_#UNREAD
Bentley had a repair video for the codes my car was putting up, involving fixing the ground wire which we did.
https://www.youtube.com/watch?v=FjGkFqdS52w
It involved the following codes.
Quote:
ay,12,June,2016,11:39:56:64845
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: 9BWGL21J044000688 License Plate: FPC-486
Mileage: 196540km-122124mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWGL21J044000688 Mileage: 196540km-122124miles
Address 01: Engine Labels: 06A-906-032-BEV1.clb
Part No: 06A 906 032 MT
Component: 2l LEV2 A4 MQ5 G 5275
Coding: 00001
Shop #: WSC 00000
VCID: 7CF90CCB6C162ADE37-513C
9BWGL21J044000688 VWZ7Z0C7632736
7 Faults Found:
17746 - Camshaft Position Sensor (G40)
P1338 - 35-00 - Open or Short to Plus
17763 - Cylinder 1 Ignition Circuit
P1355 - 35-00 - Open Circuit
17769 - Cylinder 3 Ignition Circuit
P1361 - 35-00 - Open Circuit
17772 - Cylinder 4 Ignition Circuit
P1364 - 35-10 - Open Circuit - Intermittent
17766 - Cylinder 2 Ignition Circuit
P1358 - 35-10 - Open Circuit - Intermittent
18613 - Performance Malfunction in Cooling System
P2181 - 35-00 -
16840 - EVAP System
P0456 - 35-10 - Very Small Leak Detected - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000 785 00200
VCID: 336BE7F751C825A6A6-5120
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1M AIRBAG VW51 02 0008
Coding: 12621
Shop #: WSC 00000
VCID: 224512B3AE32BC2E5D-5120
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 807
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 15332
Shop #: WSC 00000
VCID: 65CF49AFFF9C8B16F8-5102
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: 70E128FB305E5EBE9B-5120
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00000
VCID: 3773D3E715B0C9869A-4B00
Subsystem 1 - Part No: 1C1959801A
Component: 8C Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8C Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 8C Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
There's a service bulletin to add a ground to the coil pack harness.
Aftermarket coil packs can cause these codes.
A damaged coil harness can cause these codes.
Yeah the Bentley video I posted is directly involved with their repair procedure for this TSB. This is the repair I carried out. I was really hoping this would be the fix.
Any chance the ground point is bad? There are a few others to use under there. Would ground point really matter?
If the ground is clean and you used the point called out in the TSB, the I would say your ground is good.
Aftermarket coils installed? How does the rest of the harness look? How do the rest of the grounds look?
