JHZR2
Staff member
The fuel tank filler in my 93 300SD has a lot of rust. Probably because the car sat a number of years.
I want to put a Racor filter on it to help with keeping the IP safe, but I need to know actual flow rate. I tried to pull the return hose to measure the flow I get at idle and 2000 RPM. The hose would not come off. I pulled hard and broke the banjo.
It just pulled out and I can’t get it back in. Not sure if it was soldered or what.
The hard line will spin inside the bore of the rubber hose, but it will not pull out. It’s stuck hard in the rubber return hose. The return hose is called a cigar hose, it’s bigger in the center than on the two ends. I’d like to avoid damaging it….
So any thoughts on how to fix the banjo bolt, and how to get the short part of it out of the hose without damaging the hose?
I’d like to take the car on a 300 mile trip early next week and obviously that can’t happen as is.
Thanks!
Thanks!
