Front driver caliper has been dragging for a while now, sometimes worse than others. now it's down to the backing plate and i'd like to avoid ruining the rotor while i wait for my new brake hose and front pads to be delivered in about a week. as far as I'm aware, the caliper has an M11 Banjo bolt, which is a size you can't find at any in person establishment. would it be possible to drill out the end of the brake hose to the next largest english size (7/16???) and reuse the crush washers? all other 3 wheels have plenty of pad material left and this solution would be very very temporary, just until i have new pads and the hose. i'm also certain i'd have to disable the ABS module so it does not tweak out at the fact that one wheel has no braking power
