This is on the ‘05 Corolla. Gradually lost pedal feel on the way back from work last week. Pedal would sink almost to the floor but not quite. Between this and the Armada oil change with particles what not, things seem to be going poorly vehicle related
No visual leaks at the wheel cylinders or the calipers. Jounce hoses look fine. Level in reservoir didn’t drop.
All of which led me to believe it was the master cylinder, so I ordered one off RA.
Swapped it in after work today. I followed the instructions for bench bleeding (keep it level, fill up the reservoir, let them fluid start dripping out of both ports, cap the ports, firmly push the plunger an inch and look for bubbles), verified no bubbles in reservoir and the plunger was stiff except for maybe 1/8” movement.
Got it on the car which was a challenge with the back/rear hard line. Master cylinder did get a little low during getting it in the car - i kept it topped except one time it dropped a hair below the min line.
Tried bleeding the brakes - I have marginally better pedal travel. I’m able to get clean flow of fluid out of the RR, RF and LF bleeders. I’ve gone through about 48oz of brake fluid on the LR bleeder and I still keep getting bubbles.
Anyone have suggestions on how to proceed? I’m completely lost on this one…
