The Critic
How long ago was this?I had no issues with the Posiquiet pads. I did have to bed them in with about ten 60 to 5 slow downs to heat up the pad and rotors to get a proper transfer layer on it
3 years agoHow long ago was this?
We installed 4-5 sets of the copper free ones. Probably within the last year or so. I think 2 or 3 of them developed pulsation from pad deposits within 5-10K.3 years ago
Centric said posiquiet ceramic did not require the heat cycling to bed the pads. I didn’t like the performance so I did it, and once I did, the performance difference was night and day
Go do some 60 to 5 mph stops to get them even the first timeWe installed 4-5 sets of the copper free ones. Probably within the last year or so. I think 2 or 3 of them developed pulsation from pad deposits within 5-10K.
There is a no safe area to do that around here. It is also not part of the OEM service procedure. There is zero reason why an aftermarket OEM style replacement pad should require such break-in methods. Dealer pads do not require this and establish their transfer layer just fine.Go do some 60 to 5 mph stops to get them even the first time
Then you should have spent the extra money on dealership pads.There is a no safe area to do that around here. It is also not part of the OEM service procedure. There is zero reason why an aftermarket OEM style replacement pad should require such break-in methods. Dealer pads do not require this and establish their transfer layer just fine.
I’ve had Zimmerman rotors where the coating came off a bit, others where as it scraped off it literally turned into little bits of folded up material.The real European rotors (OE, Zimmerman, etc.) use GEOMET on their rotors.
The $20-$40 silver rotors that most folks are buying from Raybestos/Centric/etc are rotors that have been painted with some type of paint....and it is not GEOMET.
