Water softener doesn't scratch porcelain.Yes it worked but I don't know if it scratches the porcelain. The stone gets used up and it disintegrates while using.
Too noisyThat's gross, flush it.
Too noisy
If it’s yellow let it mellow
If it’s brown flush it down
It’s just urine. Take it easy
Now there’s an ideaNoisy? You have a straight piped SBC powered flush or something?
Flush. Hell flush 2 or 3 times just in case. It's just water, it's almost free.
But the pumice stone might.Water softener doesn't scratch porcelain.
No pumice is softer than porcelainBut the pumice stone might.
Ok?But the pumice stone might.
We have two Toto toilets. The old one gets the ring horribly and the new one doesn't. Both are supposedly have the glaze. The new one has been in service three years now. Am going to try the Scrub Free toilet bowl cleaner!I was going to blame low flush toilets but you could be on to something. All our pots are 2014 dates
If it works in Lake Havasu City it is worth trying in Kingman. Thank you.I have 2 toilets where I had to deal with this. (Yellow / orange calcium rings at the waterline of the bowl). My wife tried all the cleaners. CLR, Lime Away, Rustoleum Rust Remover Spray, Mister Clean "Magic Eraser". Name it.
None worked with any satisfaction. So I tried a small Scotchbrite Pad, (Tan, dark Earth color). And some Lime Away to wet it with. 100% success! The calcium deposits were heavy, and raised up over the glazed surface of the bowl. You could feel them with your fingernail.
I used only one finger, pressing lightly directly over the ring, using back and forth cleaning strokes. It took a bit of doing, but all of the calcium stain rings vanished. And when I dragged my fingernail over the surface, I couldn't feel anything.
I washed and wiped the surface dry, and used a magnifying glass with a bright LED flashlight, and I couldn't see anywhere that I had scratched the ceramic glaze of the bowl itself. It really worked much better than I thought it would.
Back in my custodian days we would use a mild acid bowl cleaner which we got from a janitorial supply house for stubborn stains and for maintenance (upkeep) we used a NABC orI have 2 toilets where I had to deal with this. (Yellow / orange calcium rings at the waterline of the bowl). My wife tried all the cleaners. CLR, Lime Away, Rustoleum Rust Remover Spray, Mister Clean "Magic Eraser". Name it.
My full quote:Ok?
I never mentioned anything about stones.
No. I asked if the water softener was working.My full quote:
Still don't understand?
I think it's oxalates from human urine. Known to make kidney stones with calcium and now thought to be the reason for plaque in the brain etc.Too noisy
At least it's being peed out! Nuts, green tea, almond milk, spinach? That's my wife's diet!!I think it's oxalates from human urine. Known to make kidney stones with calcium and now thought to be the reason for plaque in the brain etc.
If you leave urine in the bowl as you noted prior (i agree) its most likely the cause.. tea drinkers, greens, nuts etc....
Thats why I max out the ice on my 3 iced teas a day- really getting only half.At least it's being peed out! Nuts, green tea, almond milk, spinach? That's my wife's diet!!
