Yeah I ordered a Flashmasters on ebay. Seems ok although it's way more sensitive to misfires than the old unit.I do lot of ECM/PCMs and have used several companies, junkyard, ebay and other sources. I can say that Flashmasters has been the best in standing behind their units. They sell online and ebay. The worse is Cardone BY FAR! It usually takes 2 units to get a good one...sometimes 3!
Did the voltage regulator for the alternator fail?Thanks everyone, this gives me something to work with. I will give Flashmasters a call on Monday and see what they have to offer.
This is for an 05 PT Cruiser turbo and automatic.
Before buying a new PCM, exhaust every possible alternative. Many times a PCM is condemned but it is a sensor or other component sending false information to it. Garbage in, garbage out. Not saying that is the case but did you check for updates to software, etc? Was a $20 scanner or $2000 scanner used?Are there any company's out there with good reviews? We need a replacement PCM but I don't know where to go after reading so many complaints about most of these company's.
Contact THIS GUY:I would also try inquiring on a make/model specific forum. Often times, you're not the only one that is/has been searching for a reputable electronics rebuilder.
Contact THIS GUY:
They are not perfect but they have consistently taken care of me when issues arose. One time the PCM they sent was programmed with the wrong VIN. They had another sent immediately and didn't even ask for the other one back. Another time I was getting an issue that my diagnostics pointed to a bad PCM - I had to buy another locally so my customer could have their car back quickly - they refunded my money no questions asked. Those were 2 issues I had vs about 30-40 good dealings so I that is why I recommended them.Yeah I ordered a Flashmasters on ebay. Seems ok although it's way more sensitive to misfires than the old unit.
I only tried it because their ebay fb was near perfect.
Yes, the car seems to run perfectly normal. The only problem is the steady on check engine light. We are the original owners, the car is completely stock and the codes are P1603 and 1604.I would normally say the same thing, But it is a PT Cruiser.....
I code used older Chrysler PCM's using my Autel with good success. If this cars been "Tuned".....Internal PCM errors can happen.
OP, Does the vehicle run & okay otherwise??
This feels like an electrical tape fix.....Yes, the car seems to run perfectly normal. The only problem is the steady on check engine light. We are the original owners, the car is completely stock and the codes are P1603 and 1604.
I have to learn how to do that, I have an upper end Autel and love it.I would normally say the same thing, But it is a PT Cruiser.....
