Regular E-core users please check in
Pullman Wa
I was wondering who uses e-core's on a regular basis and what are their opinions about the construction of the filters. I know that many AC Delco oil filters are of e-core construction so anyone who has their service work done at a GM dealer is a dedicated e-core user (like it or not). Is that nylon cage strong as steel or does it really have to be?
I think the cage is strong, but too widely spaced to give proper media support. I quit using them. I'm also not a fan of bypass valves that rely on the flexability of rubber-like materials on cold days.
I had a large stash of AC Delco pf1218 Ecores I got on clearance at Walmart for $1.50 each. I have used and cut open 4 or 5 and they have all looked great inside. I prefer the AC Delco classic filters, which are still made with metal end caps and center tube., but if I find a deal on Ecores, I have no trouble using them.
+1
I use AC Delco parts on my parent's LeSabre and put the first E-core filter on yesterday. I will take a look inside next oil change. I have confinence that these style filters are engineered to work.
If the potential for a problem is genuine and higher than "normal," or I experience a problem, then I will use a Purolator Classic or a non E-core, if I can find one.
+1
And that's been proven here that design can be a problem.
i use them and cut them open. never an issue, i got a few in the garage to cut open, just too lazy.
Winning!
I have been using the deere variation of the e-cores for atleast a year and a half(whenever they switched over to them) on 5 different autos with no issues that i'm aware of.
at oil change time i always look inside and the cage has always been intact and everything else has looked good
I used to use ST e-cores exclusively, but after cutting open two of them and seeing media failure in one and a defective cage in another, I quit using them.
These were two filters for two different applications that were cut open a couple of weeks apart.
I used them @ $2.02 ..don't care for them at their current price. They were trumped big time by AA's BOGO on TotalGrip ..but that went away ..but other filters are only $0.25-$0.50 more
They were great of the beater extended fleet.
I have used them and cut open the last one that I used.It may have just been me but the endcaps could have had a better hold to the element.It has been a little while since using the ST but from what I remember,the element pleats were well spaced and it had a good amount of filter material.The endcaps just werent bonded as good as they should have been,they should have been harder to get loose.
I also am not real crazy about the cage,it needs to have more element support,there is too much gap in the cage to give the element the support that is needed.
Originally Posted By: goodtimes
I hate it when some are favored to check in first. Why can't everyone check in?
cause the threads for everybody get swarmed by the usual haters.
