Redline vs Mobil 1, any real difference?
I have a 1985 Ferrari Mondial QV with a flat tappet engine. I will need to do an oil change in the next couple of weeks. Would there really be any benefit in switching from Mobil 1 15w50 to redline 10w50? I do drive the car rather hard and frequently cruise at speeds of between 100-120 mph where the RPMs set between 5000-6000. The engine redline is 7k. The oil temps rarely exceed 210F.
Redline is significantly more expensive, and its availability much less, but if it would significantly reduce engine wear it would absolutely be worth the price. If the real world difference is negligible then I might be better off sticking with Mobil 1.
The engine in top gear is spinning those rpm's at 100-120mph?
