Just wondering if anyone has experience running superlight or lightweight shockproof in their differential either straight or mix with other gear oil? What is the review and the oil change interval you used?
Thank you, i also have good result with MT90 before, but some people complain about noise on their 75W90, that I also experiencingnever used shockproof BUT been using their 75-90 in the rear, there are several + their great MT90 in manual transmissions, the only kind i buy!!
Awesome avatar.l use their heavy in my diesel Rover differential. The diff is noisy, but the bearings and backlash are fine. I tried the Heavy Shockproof and it reduced the noise noticeably.
I use Redline gear oils in most of my fleet, except for the Porsches.
Do you mind to share the oil change interval for the mix?I'm a mixer! Also a pioneer of the Redline MT-LV and Superlight Shockproof 50/50 mix. Now used in 3 different VW 02J 5 speed manuals. It works very well for higher mileage VW gearboxes with worn synchros. I plan to try it out in my 02Q 6 speed manual next to see how it goes.
I don't know yet, MT-LV is a new product only out for a couple years. When I first tried blending them together I could not find any single vendor that sold individual bottles of both formulas it was so new. longest it's been is ~ two years and I sold that car to my Mechanic. He still drives it though.Do you mind to share the oil change interval for the mix?
Thank you, i believe mola in the past mentioned about the calcium in the shockproof. I am just wondering why redliine does not recommend for street use if there is no water contamination and sub zero temperature exposure for open differential application. The reason OE manufacturer to go thinner is to increase efficiency, so if shockproof with extra slipperiness and adequate protection can do the same function, why is this inot recommended?I have read the magic ingredient in shockproof is a megadose of calcium. I would think you would want to mix with a lighter than spec gear oil to account for half of that dosage throughout the final mix.
C.U.N. probably has the right idea with the LV.
I have pure heavy shockproof in my mustang's 7.5 rear and it runs great, biggest improvement of anything I've done to the car, but probably has more to do with replacing the gasket while changing. Plan to keep it until I find another fancy gear oil on sale cheap.
It has solids in it. It’s kinda chunky, maybe that’s why.Thank you, i believe mola in the past mentioned about the calcium in the shockproof. I am just wondering why redliine does not recommend for street use if there is no water contamination and sub zero temperature exposure for open differential application. The reason OE manufacturer to go thinner is to increase efficiency, so if shockproof with extra slipperiness and adequate protection can do the same function, why is this inot recommended?
Thank you, this should be good alternative to stay at 75w90 grade, even though I am looking one with less fluid friction and lighter viscosity. Mobil has it on the gear oil ls version but milder EP and perhaps less capability for extended drain.Some might be shocked to know that guys with 12L diesels produce significant shock loads. Have used this in 4WD’s for years and it’s popular with Porsche trackers:
https://www.mobil.com/en-us/commercial-vehicle-lube/pds/gl-xx-mobil-delvac-1-gear-oil-75w90
