Redline Non Slip CVT Fluid
Kansas (316)
Voa sample here it is!
If the picture is hard to ready I will type up the data tonight. Thanks and have a great day everyone.
Well they consider extending the service even on the red line to 30,000 miles. I will probably just change it every other oil change
Nice!
I like the fact it's motor oil colored instead of being dyed red, etc.
I'm not sure I see the point of it over an OEM fluid though, if it's indeed $18-20/qt.
Well the Honda oe is over $15 a quart, the Castrol CVT fluid is on Amazon for $77 for a six pack. I posted when I first bought this stuff that I got it for $13.95 a quart. A significantly better fluid. Many have told me that I'll notice a big improvement but I was changing my fluid anyways every 10 or 20,000 miles.
Changing every 20,000 miles is good enough, except that you have 80% stop and go traffic every day.
i changed ALL my drivetrain lubes in my 30 thou 2011 Frontier to Redline products + see about 3 mpg improvement going from 16 to 19 is worthwhile IMO + will prolly make everything last longer. real synthetics are surely better its just if its worth the xtra $$$ for you!! my 2001 jetta O2J 5 spd manual of course shifter poorly from new but Redlines MT90 fixed that + my replacement a 2001 TT 225Q 6 spd manual also gets it!!
Yeah I'm changing the filter that connects to the warmer too. I might undo the bolts underneath and replace gasket and plastic filter inside too.
I have a 2012 Prius V and from all accounts-the equivalent of Toyota WS atf is recommended, which would be Redline D6, which I have in my transmission now. Curious that Redline also recommended this non slip CVT fluid for the car as a secondary recommendation. Checked with Dave and he confirmed it.
“The Prius has an e-CVT, i.e. an electrical CVT. The concept is the same as a classical mechanical CVT, in the sense that it gives a continuous variable transmission from engine to the wheels. However, the implementation is completely different. Instead of using a friction belt, it uses two electric motors and a differential gear.”
Was curious if the cvt fluid would be suitable for the vehicle… Redline’s recommendation was the first time I have seen the recommendation for cvt fluid as well as the standard low viscosity atf.
Castrol has a universal atf/cvt fluid in gallons at Walmart. I called Castrol and they didn't want me mixing the Transmax CVT with their new fluid but I think the data sheet was fairly close between the two. Now that Castrol got stupid on their price for cvt fluid, I was able to get Redline for cheaper and bought a ton of it.
They told me the same thing when I emailed them asking if I could use the universal fluid in place of the cvt fluid. They didn’t want me mixing them, which I wasn’t. I was going to do a 3X drain and fill like I did with the cvt fluid.
But I ultimately decided to just stay with the Castrol cvt fluid. It’s every 30K miles and every 2-3 years. No biggie
Prius “CVT” should use WS, not CVT fluid.
The transaxle on those are bulletproof and are unlikely to be a reliability issue…even if you never replaced the fluid.
